Shark-MegaByte
- Dec 21, 2004
I'm replacing my Antec TruePower2 550w. It doesnt seem to be able to carry the load during gaming - Asus PC Probe gives 12v readings of 11.9 idle, dipping to 11.78 under load. The 'supply is being RMA'ed to Newegg. I know BIOS and software voltage readings are usually not 100% accurate, but in this instance everything else I've done trying to identify the problem part has seemed to clear my cpu, system ram, and video card/s of suspicion.
I don't want to mess around with trying a lot of PSU's, but i dont have a lot of extra money to blow, either. Hoping for a price tag around $100, but willing to go over if absolutely necessary. I'm not going to add any major components - don't need or want more drives, don't want to run 2 gpu's and my motherboard doesn't do that anyway - so I'm looking for something that will support my current hardware rock-solid 100% and that's all.
Antec is no longer an acceptable brand.. my confidence in them is drastically diminished.
Here's the setup, re-arranged from my sig:
Asus A8N5X
AMD64 x2 3800+
EVGA 7900gt KO 256mb ... or Sapphire x1800xt 512mb (I was testing both; havent decided yet)
Corsair TwinX ddr400 2gb
WD Raptor 74gb SATA
pata Pioneer DVD+/-RW
Linksys SRX pci wifi
3x120mm fans
==Usb devices==
Kensington SlimType usb kb
Logitech cordless MediaPlay mouse (usb)
Sandisk Cruzer Micro 256mb usb flash drive (connected often)
LG vx8100 cell phone charges and takes data from BitPIM, usb (connected often)
Wingman Extreme Digital 3D usb (connected occasionally)
==(other)==
XP Home
NEC MultiSync 90gx2 19" 4ms lcd
Asus A8N5X
AMD64 x2 3800+
WD Raptor 74gb SATA
3x120mm fans
==Usb devices==
==(other)==
XP Home
