- Nov 22, 2004
Hello again everyone.
I just got done purchasing a new pair of logitech Z-5500's. Yes after holding back this long you guys finally convinced me to purchase a set of them.
Now that my order is in(they should be here sometime this week) I need to figure out what is the correct placment for them????
First and foremost. Heres a pic of my room with my current AltecLansing ADA-885 setup:
EDIT: REFER TO PHOTOS BELOW!
As you can see I am somewhat limited with space.
Try and imagine this. If I am sitting up strait in my chair the front speakers are at ~-15degree decline from my ears. They are placed approximately 2.5 feet from me. Now the rear speakers are where they should be (i think) they are exactly 90degrees on either side from me, and both the left and right are ~3ft from me.
Now for my question. Shold the front speakers be further away from me and higher (need an audiophilie's opinion(basically will it sound better)? Or should the placment of my new Z-5500's be exactly where my current speakers are (oh and this setup doesnt have a center channel, I was going to mount the center Z-5500 to the bottom of that shelf above my monitor.
I was originally thinking about mounting the front right on my wall, and the front left will sit right next to my rig, but wasnt sure if that would be a plus or not.
The reason I need to know this is because I am buying a HIGH QUALITY optical cable (yes it needs to run from that X-FI breakout box in my stacker to the right input on the Z-5500 speaker. So I need to find out if I need a 8ft or 12ft cable. Is it ok to coil up fiber optic cable if I have excess? Is there any negative effects to getting a longer cable(say the 12 ft one)? I am thinking of getting a Belkin PureAV SILVER optical cable, any objections? I need to know before I go and buy a $50 cable that ends up being too short
Thanks for any recommendations in advance!
-DaRkF0g
-DaRkF0g
