Recommend me a video card please?
Hi, i need a new graphics card for my new spec machine.
The machine will be quite high end - conroe E6600, 2gig RAM, bla bla.
Should i go for 7950gx2? I read through the thread that asked this question and the general consensus was - yes if you play at high resolutions. That is great but what if you DON'T play at high resolutions and only play at 1280x1024? Is the card still worth it then.
I only have a 17" LCD screen and i really don't want (or can afford) some of these beheamoth 20+ inch screens - how do you people find the SPACE!!
ANYWAY, i am looking to buy the gx2 or would it be a waste of money at 1280x1024 and should i wait for the x1950xtx?
Suggestions?
Thanks
x1950xtx will blow the sh*t outa the 7950gx2, or you could wait for dx10, and use like a 7600gt or x1800xtx and use the extra few hundred dollars for a nice dx10 card, but considering only 1280x1024, and the sli 7950's and x1950 get steady framed at like 2048xw/e, just go with a 7900gt or x1900xt
dx10 is going to be here real soon, so i would wait. plus at 12 x 10 you wont need that much power. get something good but i wouldnt go all out till you can get a dx10 card. 7900gt's are cheap these days, or if your an ati guy 1900gt.
Yea - hmmm i know about dx10 and i am probably deffo going to wait and buy a dx10 card, despite everyone saying the first gen dx10 cards will suck i doubt it!
Thing is god knows how long til dx10 card comes out GRRRR!!! How is resolution of 12x10 an 'only'...? Is it common these days for gamers to have 20" monitors and upwards!?
http://www.steampowered.com/status/survey.html
The most common resolution according to the last Steam results is 1024x768 at 47.5% and a relative close second is 1280x1024 at 36.11%. Results of resolutions higher than these don't even try and hit double figures.
I think the point coolxboxgamer was trying to make is that to get a 7950GX2 is pretty much overkill for that resolution and the alternative cards he suggested would likely give a comparable performance at 1280x1024 to the 7950GX2, with the latter really pulling out at higher resolutions. My monitor (in sig) gives me 1280x1024 and I am more than happy with my X1800XT.
yes, i was trying to say a 7950gx2 will be HUGE overkill, a x1800xt or 7900gt will do fine at that res with some aa and af
It also depends on what games you're playing or will play in the next several months. If you plan on lots of FEAR and Oblivion, even at 1280x1024 you'd see a benefit from going past a 7900GT (at least on higher detail settings).
