- Jul 29, 2011
I'm about to embark on a little project, building myself an external radiator setup. I'm going to be integrating it into a small cabinet that I can keep instead of buying new radiators/pumps/reservoirs for every case.
That being said, I have space for two 560mm, I've settled on the Alphacool UT60 full coppers. I figure this is enough for even the most extreme rigs.
I need suggestions on the best pump setup to run those two, plus a few feet of tubing to the machine and obviously CPU and GPU blocks. I have a single MCP350, but it doesn't necessarily need to be used for this.
I'm thinking I will want at least 2 pumps in series to make this work and have some redundancy, if I added a second 350 with a dual pump top would it be adequate? Should I go with 3? There won't be any high restriction blocks like VRM/RAM/motherboard.
The only consideration is that it must be pretty quiet.
