Recommend me a New PSU
Nirad9er
Could you recommend me a PSU that is fairly good but not too expensive around 480watts. I have an antec trueblue 480 but I believe its going bad on me. I need something to replace this thats about the same quality or better.
Thanks
$49.99 & shipping [24-pin & 20-pin]
FSP Group (Fortron Source) AX450-PN ATX12V 450W
3.3V@30A, +5V@28A, +12V1@18A, +12V2@18A (+12V@29A total max), -12V@0.5A, +5VSB@2A
http://www.newegg.com/Product/Product.asp?Item=N82E16817104954
$52.50 & shipping [24-pin & 20-pin]
XCLIO XClio 450BL ATX 450W
Hold-up Time >20ms at full load, nominal line
Efficiency > 70%
Output +3.3V@32A, +5V@30A, -5V@0.5A, +12V1@15A, +12V2@17A, -12V@0.3A, +5VSB@2A
Approvals UL, CUL, TUV, CB, VDE, FIMKO, DEMKO, NEMKO, SEMKO
http://www.newegg.com/Product/Product.asp?Item=N82E16817189003
$62.82 & shipping [24-pin & 20-pin] Modular
Antec SmartPower 2.0 SP-500 500W
+3.3V@32A, +5V@35A, +12V1@17A, +12V2@19A, -12V@0.3A, +5VSB@2A
http://www.costcentral.com/proddetail/Antec_SmartPower_20_SP_500/SP500/F09966/
Lots more: http://www.hardforum.com/showpost.php?p=1027898523&postcount=7
And: $79: http://www.hardforum.com/showthread.php?t=955333
Good Luck,
Dave ;)
Think about where you want to go with your system If you plan to upgrade in the next year then get a bigger and better power supply especially if you want to go SLI
