Recommend me a high quality DisplayPort cable please.
xDiVolatilX
Hey guys my DP cable is too short. Help me find the best quality for the best price. I need a 10ft cable as mine is too short.
I want the newest current technology cable with the highest bandwidth & it needs to be 10ft.
Thanks in advance.
Are you using this one?
Do you think It's good value? good quality?
I've never heard of "mono price" brand :alien:
no, ive got the hdmi and its fine.
yes, and yes.
really?! they are kind of a "go to" store/brand for cables. theyre about as good of a bang-for-buck as you can find.
Am I missing where the cable costs $80?
ah my bad? the url is .com but i got redirected to .ca....
.ca
vs .com
Ya that Maxonar one looks great. So the one I bought came in. It runs 165hz @ 1440p 8-bit RGB perfectly. Worked on the first try. It was the cheapest one I found with a lot of positive reviews. It was this one
https://www.amazon.com/gp/product/B081JLGSB5/ref=ox_sc_act_title_1?smid=A2BTA8BV0FHMGX&psc=1
Aside from it being a brand I've never heard of lol The cable seems to be of decent build the nylon braided sleeve feels good It's long at 10ft for only 10 bucks I'd say It's a win. Longevity will be the only question let's see if it stays working perfectly for good. If I have any issues I'm going to buy the Maxonar brand cable for sure.
