Recommend me a Heatsink
Mikesta
I would like a heatsink that fits the Asus A7N8X Deluxe.. It should be copper which will work out better..
I was thinking of getting a really good Heastink and putting a normal 80mm led fan on it would that be effecient to keep the temperatures around 40C ?
I use a Thermalright SLK 900A with a Papst 26cfm 80mm fan, and it's almost silent!
It keeps my stock 2500+ @ about 40 deg C under full load!
well, the link didnt show the compatibility chart but I did find it but its down.. So I need to find out :/
nvm i found out that it fits.
