Recommend me a good modular 1000w psu
Crisis!
Hi guys, recently I've been trying to get my hands on a Corsair HX-1000, but it seams on every site throughout Australia it is out of stock (Australia is useless like that sometimes :p) Anyways is anybody able to recommend me another good reliable 1000w psu?
SilverStone's Strider Plus series is excellent. I'm using the 750 watt version in my new SFF build.
SilverStone ATX12V/EPS12V 1000W Silver Modular PFC Power Supply ST1000-P (Black)
awesome i'll add that to the list of stuff to check out, also it doesnt have to be limited to 1000w, just nothing less, and nothing stupidly high like 1500w
not that it matters, but why do you explicitly require 1000w? i mean, 850w could tri sli fermi (though with very little room for degradation) :p
Well I will be using a 5970, but I wanted the headroom to be able to get a second one if I desired in the future, my original plans were for an 850w psu but after looking around about whether or not that would be a smart thing to do with 2 5970's, I found out I would probably be cutting it fine, I have extra money to spare and I like to have that extra bit of headroom, it wouldn't cost me that much extra and I'd feel much more relaxed.
If you want to run your PSU at max load, sure an 850w PSU probably could. With my system furmark + intel burn test hits about 800watts.
Three GTX480s can use up almost 850W by themselves, not even considering other components. 850W is not enough for Tri-SLI.
Loving my Silverstone...1500w though, so a little overpowered for what you may need...I dont see why any 1000w+ PSU wouldnt serve you well, as long as its a real 1000w+ unit and not a $80 cheap box...
If you're looking for something that's even above a Corsair, try to check on the Enermax Revolution. They had really high ratings on review sites such as jonnyguru.com having the highest PSU efficiency, and it is also modular. http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=138
ENERMAX ERV1050EWT Revolution 85+ 1050w
Hope that helps :)
I just picked one of these up to power the system in my sig, and i'm loving it thus far.
From the review of Johnny Guru
Value (30% of the final score) - Provantage has this unit listed right now at $267.04. That's a little more expensive than the competing Corsair HX1000, but frankly this unit is a better design, more efficient, and more powerful. Another 10.
I ended up going with the Enermax Revolution 85+ 1250w, whilst the 1050w variant was available you may be wondering why I didnt go with that, reason being the difference in price was 10 dollars haha, so it didn't really make any difference price wise. But thanks for the help guys.
