Hitokiri Batohsai
- Apr 22, 2003
I'm planning to upgrade form my existing case-i-cute to a bigger case. The case criteria:
1. 5 hd bays
2. at least 3 optical bays
3. Side window
4. Great cooling with fillter for the fans(I don't like to vacum the insides every 2 months.
5. Lights optional, better with light controller.
6. Light. (this icute with 3hd 2 optical drives weighs 15kg)
7. Quiet
8. Easy to place in new hardware/removable trays.
9. Screwless optional. I don't mind using a philips
My icute comes with a 400w PSU, but when I tried placing in more hd, the pc restarts every 3 minutes. The case is a bit noisy, I can clearly hear the sound from 5 meters away. It has 5 8cm fans. 3 intake (2 front, 1 side), 2 out (rear). This case is enough for my expansion needs, only that its so difficult to place in new hd, & the calbes are in a mess, with another 2 hd, there is no way to hide any wires.
Here is what I bought for the new case/to settle the problem:
Tt butterfly 480W PSU(all cables sleeves) + a fan with fan controller. (Black color, silver sold out) Here is the link to the PSU
http://www.thermaltake.com/purepower/W00212.htm
Cooler master Rounded IDE, floppy cables. (I tried finding a Vantec sleeving kit, but all sold out).
The window is for the PSU lights glowing
& to monitor the dust, to know when to clean the pc.
What do you suggest? I could recycle some stuff from this case to place in another case. But the 8cm fans are just too noisy for the bedroom.
Here is what I have seen. Tsunami case (though it does not fit all the criterias). Any case fitting the above criteria will do.
http://www.thermaltake.com/xaserCase/tsunami/swa/swa.htm
1. 5 hd bays
3. Side window
7. Quiet
