cell_491 said:i have one of these ill sell you for $100 its a kickass monitor http://directron.com/9klr.html
yea well ive had it for 2.5 years and its been great...show me where you read somthing bad about itandré2005 said:i remember readiing about this aoc, bad bad bad montor.
cell_491 said:yea well ive had it for 2.5 years and its been great...show me where you read somthing bad about it![]()
Data said:no you didnt, maybe the spectraview.
but if you spend $700 on it you are crazy.
Please show me a link of a reputable dealer that has the item.
Becasue when i search on pricewatch, they dont even have any.
Converge said:And i wouldnt pay $700, I though it was $350...and it is, seems to be two versions though.
I meant to say froogle..
http://www.topmicrousa.com/930sb-bk-sv.html
http://www.topmicrousa.com/dp930sb-bk.html
So whats the difference between those two that makes a $400 gap?
another
http://www.buy-big-monitor.com/Mitsubishidiamondpro930sbdisplaycrt19.html
They could be out of stock, i dont know. I dont think they say on the pages.
dont speak unless you can prove your derogatory statementsandré2005 said:old old old, technology on aoc. i can't remember where. this was the time i was thinking about buying my first 19" monitor. for crts trinatron or diamondtron are the best there are.
that wasnt the point...the point was hes dissing a perfectly good product with absolutely no proof.Converge said:Cell dont worry, im not going to buy a used monitor anyways.
Ive narrowed it down to the D30sb (if i can actually get one) or the Lacie 19". The lacie basically has the same specs as the D30sb. Its right here >
http://www.lacie.com/products/product.htm?pid=10121 (Yes the hood comes off, its to reduce glare)
Data said:The lacie runs lower resolutions, The 930sb will run 2200 xwhatever
the lacie will run 1920
