Recommend Good CPU Cooler
B737Capt
I need recommendations for a good CPU cooler for E6700 mounted on a Asus P5B Deluxe.
I'm looking for the following qualities in order:
  1. Very quiet operation! Near silent.
  2. Easy to install.
  3. Good cooling.
I've got a Thermalright Ultra-120 with an S-Flex 1200rpm fan on it. Cools very well and is completely silent. It's big though.
Thermalright Ultra 120. Just make sure your case can handle it!
Looking at putting everything inside SILVERSTONE TJ09-B Black Aluminum ATX Mid Tower Computer Case. Will it fit? Is it easy fairly easy to install?
It is easy to install, but the motherboard has to be removed.
The best coolers out there are big and heavy so they need a backplate for support.
