Recommend Core2duo Mobo
Stoly
I'm turning to the darkside and replacing my A643000+ for an E6300.
I need a mobo with good overclocking and that also supports the 7950gx2.
preferably under $120.00
Good luck finding one for under $120.
The Gigabyte S3 maybe or the Foxconn, but don't expect miracles. Your best bet in the mid range price bracket is the Gigabyte DS3 or the Asus P5B
Asus P5NSLI will support the chip and video card you mentioned. It's cheap too around $120. Hopwever from what I've read overclocking isn't something that this board does well. I am not overclocking mine currently.
Get the Gigabyte DS3 and dont look back.. I hear its a very good motherboard, for only $30 more than what you are looking to pay and you will get more out of it.
Gigabyte GA-965P DS3, great OC board,have one,e6300 at 2.6Ghz without breaking a sweat.
ASUS P5N-E SLI, great OC board, have an e6600 at 3.3Ghz with just FSB adjustments, can run SLI at 8x per. I really like this board,too. A bit tight for PCI slots though. If you SLI with double wide cards, you have only one extra slot.(I realize the GX2 is a double wide one slot,not SLI in the truest sense.)
If you OC dont get the ASUS P5N-SLI. I had one and the FSB would not go beyond 296. Anything I did to try to boost the FSB failed miserably.
My favorite at present is the DS3......its a great little board for the money and will easily OC.
