Recommend: best Integrated Video MB?
Snowdog
My trusty old Radeon 9700Pro has croaked.
I want to build an inexpensive new system with integrated video to hold me over a couple of months till new midrange (256bit bus) cards come out. That is I am hoping to get semi-usable video integrated video performance to play old games (KOTOR, NWN 1) for a couple of months till I upgrade with a new midrange video card. Again I stress this is just temporary, I would rather do this, than buy a crap video card to replace in a few months. If they all suck. What sucks less?
I am CPU agnostic so AMD/Intel CPU capable both apply.
Ideally MB would have:
DVI/VGA both usable to drive dual displays, but can live with one till new card.
Digital Audio output. Either coax or optical output fine. Really want this.
1 serial port. I have an old GPS - Can this be retrofitted?)
No SLI or Crossfire as that is just a waste of money as I won't use it ever.
Prefer quality name brand: Asus/GigaByte/Abit.
Any suggestions? Is there a search engine that has MB features? Newegg listing seems inadequate to the task.
Edit: When I say inexpensive. I am look for a MB around $100, not the overpriced SLI/Crossfire $200 ones.
You might look at either a board with a 7050 chipset (Nvidia), or a 690G (ATI). I'm coming from the AMD camp with those... the video performance is similar.
My PVR runs a biostar TF7050-M2, and my main rig currently has a TF7025-M2 The main difference is the 7050 has an HDMI output, while the 7025 has DVI onboard. Of course, my main rig doesn't use the onboard video :p The onboard video sucks, but it should play NWN... I can rip the videocard out of my system and check how well it runs if you'd like though, since I actually do play that one every once in a while.
The board is a good overclocker, at least by my standards ;) My 4400+ runs at 3.025Ghz easily with the SI-128SE. If you don't overclock... even better I guess :)
I list the chipsets above so you can compare boards. I know Abit has a 690G board, for example.
Charlie
EDIT: the 70xx and the 690G can drive one digital and one analog. Of course, I have no practical experience with the 690G, so YMMV. The Biostar boards also have the serial port connector onboard... my office is a bit of a mess, but the package that the boards came with don't seem to contain the actual port. You'll probably need a spare to plug into it.
Heh, one more edit... the boards have a 3-pin connector for SPDIF and optical output. The board again doesn't ship with the plug in connector though. I had an old Soyo output board that accepted the pinout quite readily though, with an old CD-Rom cable and some heatshrink... :) Anyway, digital output is an option for these chipsets too.
I don't know what you're version of "inexpensive" is. As far as a skt 775 board w/video goes, but no vcore adjustment or IDE header, I'd highly recommend the 3 series chipset board ECS G33T-M2. I got one on Ebay for $47 bucks shipped ($14.95), put a E6420 in it, OC'ed it to 2.8 GHz (maybe could have gone higher, but no vcore adjustment) and I have used it for 24/7 folding for about 2x weeks trouble free. (praying it'll hold on until the Yorkfield and the new X38 boards come out)
Like many people, I've stayed away from anything ECS. I think they have a winner on their hands with this board. I have 2x Biostar TForce 965 boards ATM (with E6600's, super good boards IMO), along with this board (with a E6420) folding 24/7 and I haven't had the first problem with it. I've gone through 2x P5B Deluxe's, a P5B "vanilla", a A9WD-MAX (I've had some sorry luck with this board and would NEVER darken the Abit world again) and a few other boards I can't remember.
I think the fact this board is suppose to support the new 45nm chips, is cheap and with a good C2D 65nm chip is easy to OC' without a vcore adjustment (some kind of % deal, no WR OC's) I think it's the best bang for the buck and it's a good board for what it was designed to do (in the el cheapo category that supports DDR2 800, onboard video and has a PCIe slot). I've read where it's designed for a "home entertainment" rig which explains the onboard video. The video is integrated with the chipset and, no more graphic intensive things than I do, is outstanding. (onboard video, another thing I've always stayed away from, I hate memory sharing anything)
I think this board will suit you temporarily. From the reviews I've read the onboard graphics is as good as a low range VC plus it has a PCIe slot and gets the same marks as a more expensive board with a more expensive VC. (or real close anyway)
Edit: Oh yeah, I'm posting this with an open, on the floor scrapped together rig from the closet using Ubuntu converted to Kubuntu, it has a "el cheapo" P4M900 mico board (VIA chipsets, another thing I stay away from, the board was given to me a long time ago) 1 GIG DDR2 (mismatched 512 sticks) and a E6300. It's got onboard video and it was cheapppppp. (for me it was free) If I could find my E6400 I would try it, I misplaced the cpu somewhere in my spare parts stuff.
OP, did you ever figure out a board to go with?
Charlie
I scrapped the integrated idea.
I saw a good sale on a 7900GS ($99 after rebate) and decided to go with that and use it until I felt I really needed more power. By then the 9800 series may be out from NV.
Since I no longer needed onboard graphics I went with a Gigabyte P35 DS3L as it is inexpensive and has s/pdif out and has a serial port.
I have the graphics card and I am waiting for the rest of my parts to come in. First new computer in 5 years, I was using Barton Mobile 2500 Athlon XP with a Radeon 9700 Pro most of that time, so it should be nice step up.
i've used two ASUS M2A-VM. they work great. best integrated graphics as well
Good choices.
FYI, you can get a Serial-to-USB adapter (aka DB-9 to USB), for future reference.
Good choices.
Thanks there is some chance I may get a Version 2 of the motherboard, where they are switching the serial/parallel ports out for more USB, but I think there is still a serial header on the motherboard. So I would just need some kind of bracket.
I tend to use computers for 4 or 5 years, I think by the next computer I will have a new GPS, which is the only thing I have that needs a legacy port.
I have my graphics card now and the waiting for the rest of the parts to come in is driving me crazy.
I don't see rev2.0 listed on their site yet, so there's a good chance you'll still get rev1.0. If you do get 2.0 and it has the header, you can pickup a DB-9 serial port header. I'm using one right now with my DFI board, for my UPS (APC Smart UPS 1400VA).
Legacy Cable Combo, $6
