Originally posted by pbXassassinX1524
Also, what makes NOD32, in your opinion, better then AVG and PC Cillin.
This relatively unknown anti-virus is performing excellent, receiving the VB Reward on many occassions. The key feature is highly efficient and user friendly heuristic analysis, allowing detection of new viruses even without the need of constant updating. It also handles many Java viruses, IRC worms, trojan horses and other internet infiltrations.
The memory-resident anti-virus monitor (AMON) provides constant and automatic detection and cleaning.
Main features:
nice and easy to use interface;
modular design of fully 32-bit code;
extremely powerfull new heuristic analysis, also for the macro virus family
use of fast "single point" virus samples and CRC for accurate virus recognition
effective virtual emulator serving to detect the polymorphic viruses
maximum scanning speed
speed enhancement by coding the mission-critical modules in assembler
automatic control of incoming mail/files used by means of the AMON and IMON
effective anti-stealth techniques implemented in the system
algorithmic and heuristic virus cleaning available
quarantine allows encrypted storage of infected and/or suspicious files
reconstruction of system files of key importance after virus infection
conversion of doc.files after cleaning into original format
searching for viruses in encrypted and password protected databases and docs
detection of viruses in archived files
virus detection in internally compressed and/or protected executable files
define targets and rules for handling infected files
central log management
Control Center handles all operational modules
full support for UNICODE in windows2000/NT, Windows 2003 server compatible
centralized update option for easy and fast automatic updates
anti-virus operating memory (RAM) scanner
3 pre-defined installation scenarios available
one year free updates.
We are very impressed by this anti-virus; it can compete with the best, like f.e. Kaspersky aka AVP. As as matter of fact, this anti-virus is even better in regard to viruses, detection and cleaning. best choice
The VB 100% logo is awarded to anti-virus products that:
o Detect all In the Wild viruses during both on-demand and on-access scanning in Virus Bulletin's comparative tests.
o Generate no false positives when scanning a set of clean files.
