Recommend an SSD for an old socket 775 system?
Status
Not open for further replies.
Rob94hawk
Upgrading one of my old systems from Vista to Windows 10 with a fresh install.
Specs:
Antec 900/CORSAIR CMPSU-620HX PSU
GIGABYTE GA-X38T-DQ6/IntelQ9650/Thermalright 120 extreme
Corsair Vengeance CMZ8GX3M2A2133C11R 2x4GB 8GB DDR3-2133
PNY 8800GT
Ditching the HDD and going SDD. Unfortunately it's only SATA II/ 3 Gb/sec.
Usually with more modern rigs I go Samsung Pro. Not in this case. I just need cheap & reliable if possible.
Recommendations? Thanks
Re read my post.
Your post doesn't address what you are really looking for. I could recommend some craptastic drive and then you get mad because you said you don't really need something reliable...
With your response, I'm not sure I want to participate in this discussion since you aren't trying to help me help you.
Pretty much says it right there in the title.
Status
