Recommend a quad head AGP card stat
VanFanel89
I need one today, and I am gonna buy one today, I need recommendatiosn stat. I need AGP x4/x8 card preferebly with 128 megs of ram that I can stick 4 monitors on. DVI or Analog doesnt matter, just need to stick 4 monitors on it.
Or, if anyone knows of something that can feed 6 monitors, that would be great too. I have a 6 monitor setup that we used 4 matrox cards to run (which died and took the mobo with it) so now we need something new.
um id suggest 2-3 pci video cards of your choice each with dual outputs
i dont think a quad head card exist
only card i know of with more then 2 heads is that martox parahila card and thats only 3 heads
We had a 3 PCI card setup with dual heads - it took the dual opteron motherboard that was used with it.
both are AGP need PCI to run more then 1 card at atime >.> be it PCI-e or old PCI
AGP = 1 card and 1 card only at a time you could get 2x FX5200 or 9200 PCI cards both have 128MB mem and are ok in 3d
get two FX5200's or 9200's both are PCI i think newegg has a 5700LE PCI that you can get 2 of too lol
VanFanel89 said:
sweet jesus thanks!
If you can find a PCI version of that board it doesn't appear there are any compatibility warnings for that.
4 Port PCI: Part #612514
note thats a $500 card!
lol yah
we are lookin at the matrox QID card.
How much are QID cards? Anyone knows of a good legit place ti buy with with warranty and stuff? Also what is the street price for these muthafuckas?
