recommend a mobo with 2-3 pci-e (whs setup)
pettakos
Could you please recommend a reliable mobo that has at least 1 pci-e x16, 2 pci-e x4 slots for Whs setup (intel core2duo). Chipset preferably Intel P45, Gigabit lan.
Asus P5Q Premium. 4x PCI-E x16 slots (2 are electrically x4), 1 PCI-E x1, 2 PCI, 4x GigE LAN, 10x SATA...more
Thanks a lot. I also thought so.
Well, I must admit that I bought last January Asus P5Q for my Whs server, but it lacks a second pci-e slot (grhics card in case you need it) in terms of expandability..
I think I'll give it a try.
Do you happen to know of a cheap add-on 12-port pci-e sata card?
That Foxconn board doesn't meet his requirements of "1 pci-e x16, 2 pci-e x4 slots". The video dilemma with the P5Q Premium can easily be solved with this, I am currently using it and it works great for a server. Can't give you an answer about a "cheap" 12 port RAID card though (they currently go for $500-$700), you need to define "cheap". If you want to go on the cheap, I'd look at the AOC-SASLP-MV8 for WHS. Get 2 for about $200 and have 16 ports, plus the 10 on the P5Q Premium, More than enough to fill up a Norco 4020.
Sorry, that video card is out of stock there, but you should be able to find it elsewhere, like here (Google's your friend).
I vote for the two supermicro aoc-saslp-mv8 cards, which I already ordered.
But, I think, instead of buying asus p5q premium, I will use another mobo (Dfi lanparty gf-9400trs) with integrated graphics, two pci-e slots, and 6 sata on-board. I have it since last June in my Htpc setup, and since I am planning of upgrading that one with the forthcoming corei3 or corei5 embedded mainboards suitable for htpc use.
That's an even better solution. If you don't have to buy new, use what you already have for the WHS and spend the money on a system that could really benefit from new tech.
