unleashthemonkey
- Nov 22, 2009
So, my parents computer is getting absolutely terrible and runs much slower than it has a right to. I've reformatted it on at least one occasion and that didn't seem to help. Since they only use it for internet and very occasional word processing they keep using that to justify not buying a new one (even if I build them a really cheap one for about 400). I think they are about ready to bite the bullet and let me build them a new one but I figure I would try to install Linux before I give up and build something. Literally 90% of the computer usage is just internet and sometimes they edit word documents so that is really all the linux distro would have to do. The pc is an old 2 GHz P4 with 512 mb of RAM with an 18gb hard drive so I was just wondering if anyone could recommend something. I'll just be setting everything up and then leaving it so it shouldn't require any maintenance. They have almost no technical knowledge but I wouldn't be worried about them not knowing how to use Linux because they don't know how to use Windows.
Thanks
Thanks
