Wesley1357
- Jul 4, 2005
can i have some ideas? what harddrive for a hot place do you guys recommend under $250?
For one thing the only non-scsi 10k drives are raptors which come in 36gb and 74gb flavors. If you want fastest possible, get a drive with 16mb cache.Wesley1357 said:200gb... fastest possible 7200rpm (not 10k rpm, too hot). can i ask, does ide interface still has some life?
Wesley1357 said:can i have some ideas? what harddrive for a hot place do you guys recommend under $250?
Around 3 hoursWesley1357 said:today hds are so cheap!![]()
my 80gb drive takes almost 1 hour to format, how long does a 250 takes?
unhappy_mage said:
