dreamnid said:Not really a recommendation since I don't have them but the Dell switches seems to have a pretty good value and from what I heard from other people in the forums, they work very well. I think I saw the 24 port switch in the upper $300 range when Dell has their random sales.
http://www1.us.dell.com/content/products/compare.aspx/2000_workgroup_gig?c=us&cs=04&l=en&s=bsd
Didn't mean to come off like a prick, but you'd be better off saving that cash spent on the switch and spend it on more RAM, or a better HSF to O/C with, or a watercooling system.
3com is pretty much top of the line. We have 3 here at work. I just recently ordered a 10/100 24 port Linksys
deep22 said:Is it the EtherFast 3124? We have five of them at work and they're solid performers. Great 10/100 switch, you wont be sorry.
deep22 said:Hehe, I know... its a temporary setup for now... my boss is kinda sloppy about stuff. We just moved into that building.
Some people think "neatness counts." His philosophy is "whatever works."
DVAmon said:The Dell PowerConnects are pretty good but the total gigabit managed switches are about $1000 for a 12 port, and the others only have gigabit uplinks. Also the 3Com OfficeConnects are 5 ports for about $120, so do you want managed or unmanged switches?
omega-x said:would a gigabit PCI card saturate a 32bit PCI bus and be limited by it?
dreamnid said:The link I posted pointed to Dell's unmanaged switches - all of the ports are 10/100/1000. You're probably thinking of the PowerConnect 2324 which does have 2 gigabit ports, but the 2600 series are all gigabit ports unless I'm really missing something.
Deadlierchair said:1000 megabits per second.
1000 / 8 = 125 megabytes per second.
PCI max data rate = 133 megabytes per second.
dreamnid said:If it is integrated in your chipset, I don't this that is that case.
ignorance must be blissdreamnid said:That's why PCI-X should hurry up :-P
jaqie said:what you are talking about is PCI-E (PCI-Experess)
I knew i screwed it up Thanks for the correction.
