Recommend A $600 or less Digital Camera for me..!
GeForceX
I'm really behind on the digital camera scene. I want to buy my friend a really good $600 or less digital camera. Heres the following specific criterias so it could probably chime in one of your heads of a specific model:
My budget: $600 or less.
Size of Camera: Small (not necessarily pocket sized, just "small").
Memory Standard: Any widely accepted format.
Her expertise on using digital camera: Intermediate.
Image Quality: Extremely Important.
Reliability: Very Important.
Basically we're looking at a consumer level intermediate "not-too-hard-to-use" camera that is capable of capturing non-blurry images indoors and outdoors. Obviously it must have good lens and be able to capture a lot of light to increase the shutter speed. I hope any one of you might offer different models at that price point. I believe it's good enough to guarantee a very good model. As for megapixels, it should be able to take a minimum of 1280 x 960 (not sure how many MP that is). Or at least any acceptable (and memorable) sizes.
If anyone knows of any excellent specific models then please please do recommend it, even if you're not sure. :) I'll be going on a test drive for every camera there's to recommend. :) List alternatives as well...
Thanks ya'll. ;)
-J.
Hmm here are some suggestions:
Panasonic FZ20
Canon A85
Nikon Coolpix 8800
Canon Powershot G6
I can go on and on. I would suggest reading some review at www.dpreview.com
I believe he said small so the G6 (and DEFINTLY fz20) wouldn't exactly fit that bill but if that is okay then a check out a sony dsc-v3 as well! :)
the G6 isnt HUGE, but for everything else it fits perfectly
PS.....1280 X 960 is 1 megapixel :p
Canon A520. Manual controls, 4x optical zoom, runs on 2AAs. Perfect compact!
:O!!! Canon Powershot G6!!! Perfect camera. I'm gonna consider that. Seems like a real keeper. The other ones are the "bulkier" ones. They're what I'd call "semi-professional cameras". She's a petite girl. Not gonna carry another "purse" around her. That small camera seems to fit the deal. :D Pretty simple, thanks. :)
-J.
While that's nice, it's still huge. :'( It's for a lady. Not a guy. ;)
-J.
hehe yea most of them are "bigger" cameras but very nice. I honestly would look at the A85 (uses 4AA batteries but is still very small) or the A520. Out of them i would still pick the G6 thou. I guess you can say i'm a canon fan. :)
I have an A-80 great camara and i ended up paying 300 for it... now its a bit cheaper!!!
So far its fell from a 4 foot high place on top of a car onto CONCRETE, with the lens out (just set it down while taking pictures)
LUCKILY nothing broke... took the fall like a pro :) heavy duty baby :)
but sometimes its a battery hog???... really wish i invested into some rechargeable battery packs :)
