Recommend a 120mm fan
B2BigAl
I just put together my new build and I need a couple more case fans. I have several panaflos and sanyo denkei's laying around, but they're way too loud and I don't feel like volt modding or messing with rheostats. I need a good 120mm x 25mm fan, that moves a lot of air, and is pretty quiet (~25 - 28db). I was looking at these two scythe's:
http://www.crazypc.com/products/kaze-jyuni-584690.html
and
http://www.crazypc.com/products/58472.html
I wouldn't mind having something to put on my Ultra 120 Extreme either. I'm running one of my Panaflo's on there right now, but it's huge and I have to undervolt the hell out of it to keep my sanity.
Yate loons
They're just as good as Scythes and Panaflos, but cost 2/3 less. I used to be a fan of low speed Panaflos until I discovered these... They're so cheap I just buy a whole bunch and keep the extras as backup.
They are pricy but I have 2 EB Papst fans that are rated for 67 cfm that you cannot here run.
I have both of those Sycthe fans and they are both good, very quiet. I also have an Ultra-Kaze that is noisier but pushes quite a bit more air through my Ultra-120.
I ended up going with these
SilentPC gave these a pretty stellar review, almost 70 CFM @ 24Db seems like a winner to me. I like the price on the Yate's too for the price, but they're rated at 33Db which is a bit too loud.
