Recomendation for this set up?
zidion
I need a recomendation for a PSU for this set up. I was running dual PSU, but want to just go to 1.
Mobo (current one died, not sure what new one will be)
C2D e6400 (oc'ed)
(2) sticks 1gig DDR2 ram
x1900xt
(1) IDE HD
(2) 74 gig raptors
(3) seagate barracudas
(2) water coooling pumps
(10) 120mm fans
(2) cd/dvd drives
(1) pci-e raid controller card
according to the PSU calculator I used, I need ateaset 705watts (thats with 20% capacitor aging, and putting 8800gtx as graphics card, since I will upgrade later this year).
I am looking at something like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153038
I was looking at silverstone for PC&P, but didnt see any modular ones (I cant go back to normal, all the wires just drive me crazy).
any suggestions?
A PC Power and Cooling unit would be good for that much of a draw, but they don't make modular units.
You're on the right track, but I would aim higher than $750 and plan to spend a bit more than $200, the PSU is one component you shouldn't skimp on.
