Justintoxicated
- Apr 10, 2002
I reant a room so i don't have space for Jig Saws, Band Saws, etc...
I want to cut a nice window into my Stacker T01 and get rid of the ugly grill on the side.
I have some basic tools, a drill, and a dremel.
I don't think I can cut straight lines with a dremel alone though, I want this thing to look like it was lazer cut.
I'm thinking something like tin snips might work, or possibly one of those mini hacksaws? And the dremel to clean it up?
Any Cheap Tools (less than $100) that might do the trick?
Also, it would be nice if the tool could cut MDF also, I need to build a speaker box.
Thanks for the suggestions.
