Recomenadtions - New Build
I'm building my first new rig in a long time. I'm still rockin' the Athlon XP 2500+. I feel its about time for an upgrade. Heres my basic plan, tell me what you think. Recommendations welcome
EVGA 680i Mother Board
http://www.newegg.com/Product/Product.asp?Item=N82E16813188009
Intel Core 2 Duo E6600
http://www.newegg.com/Product/Product.asp?Item=N82E16819115003
EVGA 8800GTX
http://www.newegg.com/Product/Product.asp?Item=N82E16814130072
CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB)
http://www.newegg.com/Product/Product.asp?Item=N82E16820145168
SEAGATE 7200.10 320GB (x2)
http://www.newegg.com/Product/Product.asp?Item=N82E16822148140
LITE-ON SATA DVD-RW (x2) ?
http://www.newegg.com/Product/Product.asp?Item=N82E16827106047
Lian-Li PC-65B Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811112024
Logitech G5 Mouse
http://www.newegg.com/Product/Product.asp?Item=N82E16826104191
ZALMAN 9700 LED HSF
http://www.newegg.com/Product/Product.asp?Item=N82E16835118019
SeaSonic M12 600W Modular PSU
http://www.newegg.com/Product/Product.asp?Item=N82E16817151030
Acer AL2216WBD 22in Wide-Screen LCD Monitor (Black) Retail
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=231012&prodlist=nextag
Das Keyboard
http://www.daskeyboard.com/
Grado SR 60
http://decibelchicago.stores.yahoo.net/gradsr60head.html
I'm looking forward to over clocking this thing to around 3.4 hopefully. I'm not 100% on the monitor, memory, and optical drives. Just tell me what you think. Thanks!
Why the dominator ram? Very expensive, and you can get some really nice overclocks from cheaper memory. Other than that, you have a solid system right there. :p
I think that is a bit of a hit in the wallet. I would suggest getting a Asus p5B Delux, e6300, and a set of good ram like Ballistix 1000. That will save you around 200 bucks and performance will be better. imho
What memory would you suggest in place of the corsair. Ive heard good things about the corsair, as well as g. skill and ocz. What optical drives should I be looking at?
Crucial Ballistix, Buffalo Firestix, Mushkin XP, and Super Talent are also good. As far as optical drives go, the samsung or nec 18x should suffice (be sure to update the firmware). There's also a lite-on 16x w/ lightscribe that got good reviews.
