Reclocking my Memory
EnderXC
Right now my GA-K8NS Ultra-939 reports that I have a 200Mhz FSB and my memory is running at 100MHZ (DRR200). So I was thinking of just using easy tune 4 (OCing utlity) to up it to 200mhz (DDR 400). My ram and mobo is rated for 200MHz(DDR400). Can I do this, has anyone OC'ed this board before and can give me some sugestions?
i wouldn't use a utility it should already be set in your board as rated for ddr400, something is awry. Try to reset your bios to defaults and see if it comes up for ddr400. It is PC3200 right?
100 mhz memory on a 939 Athlon is silly. You should definitely see about getting that set right in your BIOS.
Defaults are 200mhz, chip and memory.
sometimes the mobo sets everyhting to the lowest possible settings (my mobo sets my fsb to 100mhz, and my multi to 6 whenever I clear the CMOS)
use cpuz or something to make sure you are actually running at 100mhz, then just increase it to 200 in your bios.
Thanks guys i set Top Performance in my bios and nowe I'm running at 208Mhz(DDR400)
