If this is normal, Marty's in some deep trouble as I'm winning alreadyzim01 said:right now I'm running 4
I have a class coming right up, I'll go and change it and then report back after my class. Stay tunedzim01 said:try it and report back![]()
Indeed, Mine's at three thoAtomicMoose said:4 seconds per frame?![]()
How many frames in the WU?Jon855 said:Indeed, Mine's at three tho![]()
Here's the log so u can see...AtomicMoose said:How many frames in the WU?
Yeah... This is why I want the GPU Folding to be allowed for the HFC... -_- I'm sure I'm not the only one out there.AtomicMoose said:So you are doing a WU about every 400-500 seconds? WOW.![]()
I am following your campainge and I am sure you can see why this isn't going to be allowed....imagine yourself on the other side of the fence.Jon855 said:Yeah... This is why I want the GPU Folding to be allowed for the HFC... -_- I'm sure I'm not the only one out there.
If u got a P4 Xeon and I got a P1, same story, no difference there isn't there?AtomicMoose said:I am following your campainge and I am sure you can see why this isn't going to be allowed....imagine yourself on the other side of the fence.
This argument is weak and here's why... if you only had a Pentium Pro, you wouldn't have entered the Bowl in the first place knowing that most players had a P4 or Xeon.Jon855 said:If u got a P4 Xeon and I got a P1, same story, no difference there isn't there?
Here's where I disagree with you, P4 vs P1 is Apple and Orange and so is P4 vs R580AtomicMoose said:This argument is weak and here's why... if you only had a Pentium Pro, you wouldn't have entered the Bowl in the first place knowing that most players had a P4 or Xeon.
As p[H] stated, GPU folding was not taken into consideration when the Bowl was created. Therefore, it is apples and oranges. They are not even in the same league.
Now under non-HFC Bowl name, I'm folding a big one now... -_- Hasn't yet completed the first one yet... Good for my points then -_- DOWN WITH ????? Marty or Moose... I'll have to flip a coin on this one...AtomicMoose said:So you are doing a WU about every 400-500 seconds? WOW.![]()
2711 171.65.103.159 p2711_GPUlambda 1258 3.00 4.00 220.00 100 GROGPU Description densign
2715 171.65.103.159 p2715_GPUlambda 1258 0.12 0.12 1.00 100 GROGPU Description densign
2717 171.65.103.159 p2717_p2714_GPUlambda 1258 0.12 0.12 1.00 100 GROGPU Description densign
2718 171.65.103.159 p2718_GPUlambda 1258 0.12 0.12 1.00 100 GROGPU Description densign
2722 171.65.103.159 p2722_GPUlambda 1258 3.00 4.00 220.00 100 GROGPU Description densign
2725 171.65.103.159 p2725_GPUlambda 1258 3.00 4.00 220.00 100 GROGPU Description densign
Which isn't too badzim01 said:yea for the 1 pointers![]()
otherwise about 8.5 minutes for 220's![]()
That is a crazy PPD rate!Jon855 said:Which isn't too badThese are the pretty numbers
unhappy_mage said:
If you are going to begin johnboy, good to know that u can't spell my name rightzim01 said:or better the mary03 probation
more for mary03
begin johnboy
Jon855 said:If you are going to begin johnboy, good to know that u can't spell my name right![]()
