Recent PC Built, But It's slow any help?
elhitman
Hello Guys,
I recently just put together a new computer which contains
amd64 3000 (stock Heatsink)
512 pc3200 (Corsair Value)
MSI K8N Neo 4
GIGABYTE PCX5750 (PCI Express) (128 Ram)
80gyg 7200 rpm hard drive
A-TOP XBlade Case (450 W PS)
Well this is the new build but now i'm getting some freezing problems sorta like the computers studders whenever i just leave it idle and just leave the music playing or just leave the IE open and whenever i come back to it it's just like takes a long time to minimize the pages or just pause the music. I used to have an amd athlon xp 3000 and no problems but now with this computer that's what i've been getting i've checked the voltages and cpu temperatures and they all look fine to me... any ideas on what i can do to resolved this issue to me it sounds like a heating problem but just doesn't make any sense here's a picture of the temperatures and voltages i have on this baby.... Thanx for any help.....
1) Make sure you have installed the chipset drivers (ie. the ones that come with your motherboard), make sure your BIOS is updated too.
2) The power supply in your case is bad. Any power supply that comes preinstalled into a non-Antec case is junk and needs to be replaced. I didn't believe this was necessary until my stock 430 watt powersupply blew up when I plugged my 6800GT into it. Yours could definitely be causing stability problems in Windows and it may be hurting your components. Be careful.
3) 512 megs of ram isn't a lot in Windows XP. It should be fine though... maybe pick up another stick of 512 if you can afford it after your new power supply
Everything else looks peachy though... seems like a nice rig! I've noticed it always takes a little massaging to get things going right the first time, but after that you'll never have problems no matter how many times you reformat... maybe it's just me though.
Good luck with that.
i think your problem there is internet explorer. :p
but really, make sure all your drivers are installed.
