I want a home theater setup for playing PC games, watching DVD movies and listening to music. I have the PC end of things sorted out (and working on the visual side), in addition I have:
I could forget about the Sonys and get some good PC speakers like the Logitech Z-680, but I figure that they'd only be good for the 'desktop' environment and not the lounge. Since I don't know, perhaps they're fine for both? I'm not keen on playing stuff real loud but realise it doesn't hurt to have the ability to do so, also I assume when something is rated higher there is less distortion for the same loudness of sound as compared to a lower rated speaker. Additionally, going this route means I have to upgrade the speakers and amplifier to keep up with the technology.
The other option is to buy a proper receiver, perhaps a Denon 3803, and use it to drive the Sony speakers that I already have. The Denon's output seems to be rated for more than 4 ohm impedance and 100 W per channel which is much higher than the Sony specification. This route allows me to slowly add better speakers later on and of course I wouldn't need to buy a receiver if I decided I need one later on. The extra cost involved could only be justified if the quality of sound would definitely be better (or at least improvable by upgrading the speakers).
Firstly, would the second choice pose a problem concerning the output rating with regard to the Sonys, or does it just mean I have to keep the volume low? (perhaps there's a way of setting the max power output by the volume control on the Denon?).
Secondly, which would you say is the best route to take and why?
Cheers
- A Sony DVD player DAV-S300 (integrated reciever)
amplifier output at 30 W per channel (3 ohms at 1 kHZ, THD 10%)
- A 5.1 set of Sony speakers SS-TS300 (satellites) and SS-WS300 (Subwoofer)
Impedance of all these are 3 ohms. I assume they are rated for less than 30 W since that is what the DAV-S300 is at (came as a package). These have those banana connectors.
- A 5.1 soundcard (Game theater XP)
Cheers
