A couple weeks ago I unplugged all on my components for about two weeks, once I plugged them back in I went through and changed all my settings back to the way they were. But now I'm having so many problems with voices, they can barely be heard at a fairly loud volume and near impossible at regular listening volume. I have turned the center channels gain up, I have tried setting the crossover at 150hz and 200hz. I have re-calibrated with MCACC twice. Everything is the same, the unit still has plenty of power. I don't think anything is wrong with it, I'm just struggling to figure out why? I figured it is worth a shot to post, Thank you in advance!
System includes:
Pioneer VSK-819h-k
Polk Monitor 60 front stage
Polk CS10 center channel
Polk TSI 100 rears
Samsung BD-D5500 BD player
Everything is going through monoprice HDMI cables, samsung BD is set to PCM and the first time the system is turned on the first play back I don't get any center channel and power cycling the receiver fixes this. But when the unit is on Bitstream, I get loud static. This is the lesser of two evils. Is it time to replace the receiver?
System includes:
Pioneer VSK-819h-k
Polk TSI 100 rears
