I have to tell you, I'm thinking about moving in! The thing is massive inside!
I moved my server out of a Lian Li PC-60USB case into this new server case and am quite pleased. The only gripe I have is that the motherboard tray isn't removeable. But that isn't such a big deal because there is so much room in the case that getting everything in was a piece of cake. There were a few reasons that I had for moving the server to a bigger case.
-More room for drives (I now have spaces for hard drives. The Server currently has a 80GB system drive and two 300GB data drives but I plan on adding a SATA controller and expanding that drasticly.)
-Better drive cooling (The PC-60USB case is great for 1-3 hard drives but if you add anything more than that it gets really cramped and hot)
-Room for a EATX motherboard (I plan on upgrading to a dual Opteron motherboard in the near future and the the PC-60USB case doesn't support the Extended ATX boards.)
I would highly recommend this case to anyone looking for case with great cooling and a ton of room for expansion.
