For use in my P-180.
Needs to control 2 120mm San Ace fans and a few others.
Must support 4 pin Molex.
I'd like support for 4 fans minimum of 2.
Price isn't much of a concern so much as quality and reliability also style and looks will factor into it.
If I can keep it under $75 I'd be happy though if I HAVE to go higher I can.
Lemme see what you've got. I love my San Ace and Delta fans but they're really loud at full speed and I don't need them running that high all the time so I'd like to be able to adjust them.
Thanks
Thanks
