- Apr 13, 2000
I had two 1 TB drives in RAID1 for a while, then the array became degraded, I replaced one of the bad drives and reformatted it under the BIOS menu (the one accessed by CTRL-A). So then I went back under Windows 7 and opened the Adaptec Storage Manager, I see the left side drop down list tree "Direct Attached Storage", drilled down to "machine name"(local system) to controller 1 (SATA HostRAID)
Under the properties on the right hand side, I have the yellow exclaimation mark of the controller, obviously because only one drive is working of the RAID1 array. Port 0 is optimal, Port 1 is "Ready".
My question is, how the hell do I rebuild the array? I right click on the Port 1 ready drive and I get grayed out options that say "Hint and tips" up top, then create simple volume, creat hot spare volume, and lastly, change write-cache mode to write through. WHERE IS REBUILD ARRAY?
