Ok, this project has been a very long time in the making, but I'm finally at the point where I can get somewhere with it. This is going to be primarily a weekend project, so no guarantees on how speedy things will go.
Overview:
Let me fire up the Internet Wayback Machine to get you all caught up to the present.
Once upon a time, I started a thread to flesh out some ideas I had concerning a console radio I picked up at the GoodWill:
Throughout the course of that thread I posted a few pictures:
...and got some advise, which generally amounted to "we think it would be neat to build your own, but don't know enough to really help. Seek out the experts, they can be found at diyaudio.com.
Overview:
- Bought a Console Stereo at the local GoodWill
- Instead of "hiding" the mp3 server, let's celebrate it!
- Going to replace its current innards with a modern receiver and speakers
- Going to integrate a PC to act as a music (mp3/flac/CD's/whatever) server
- Going to try to keep it looking completely stock from the outside
- Will eventually have a touchscreen LCD under the lid for computer control
So I'm at the local GoodWill the other day and I see an old console radio (kinda like this one, but much less ugly). I picked it up for cheap to mod into an mp3 server. Basic idea is that instead of hiding the mp3 server in a corner and running it to something else, why not make it a centerpiece unto itself.
I have most of the computer pieces here already (scavenged from my heap), aside from an M-Audio Revo for the pc, but wanted some input on a few points. The built in speakers are utter crap. I plan on pulling the guts out of the sides and replacing them.
1. Should I build my own custom speakers/boxes to mount into the space, or should I buy something prebuilt that is about the right size and mod them into the space available?
2. If I do the former, how would I go about building speaker cabinets and what is good to drive them, or should I not try, and just buy some to put in (in that case, what would you all suggest)?
3. In either event, what should I use (receiver or otherwise) to drive the built in speakers? Keep in mind that this is just going to be used for music, not movies or anything, so I would think that 2.1 is the most I am going to need.
Things to consider:
- I am on a budget, so price is important.
- I want to keep the unit as self contained as possible (will mod a 15" lcd, touchpad and keyboard into the top compartment for I/O).
- Aside from some new paint, and new fabric to cover the speakers, I want to keep the unit looking stock.
(sorry in advance for the double post)
Here is the front of the unit with the top open. I will be replacing this top with one that opens all the way across the console, instead of having the split.
Here is what the speaker section looks like from the front. Yes, the fabric will be changing.
Here is an overall of the back.
Closeup of the left side.
Closeup of the right side.
And here's what's in the shelfy bit on the right side.
