Rebuild raid10 on sb750
maverickso
hello, i have software raid10 on Gigabyte mobo on SB750 with 4x1TB Samsung F103SJ hard drives. Everything was working fine and tonight i heard a click sound on one of disks like it lost power after that my partition table and whole array has vanished. Can someone explain me what to do and how to rebuild array becuse everything i have is on disks. I can't boot system becuse i dont have even created partitions :). SB750 raid bios is very simple and I can't find any stuff to work with array like rebuild of something else. What should i do?
I would boot off a linux livecd like sysrescuecd and see if the array is recognized. This will however require you to understand a little linux.
I am noob for linux :), no it say that everything is functional. After that click sound raid could not be found so I shutdown computer and check every cable sata and power and then after that everything was fine but array was wiped
What does the BIOS say about the status of the raid? Or doesn't it have the option of setting up the raid in bios?
it say that everything is functional after I plug out and then plug in cables. Everything is ok but no data on array. The bios is retarded nothing to work with array just to create and delete
