- Feb 29, 2004
Okay guys, got this annoying problem with my video card. Sometimes when I play cs my computer just restarts. On steam yes.. It happens on the load. I'll join a game and it will start up then i'll alt tab or even just let it sit there and the screen will go blank for a sec and just restart. It's really pissing me off. I have an x800 pro with the 4.6 omega drivers. Happens on all drivers even after it's been cleaned. Didn't do this before my format
. I have an antec 380watt truepower that came with my case. It seems pretty good but i'm not so sure anymore. I have a DVD drive, lite-on cdrw, 1 stick corsair ram a mild o/c on the cpu (not 2.3ghz anymore as sig says but 2.2) asus a7n8x motherboard, I took out the sb audigy just to test. Anyway anything I could check out that i'm missing? Anymore info needed and i'll get back asap. Posted here because after the reboots it says there critical system error caused by the x800 pro display adapter. btw it doesn't happen everytime I play just enough to piss me off. I know something is wrong
. Voltages seemed pretty good, but I don't have a way to check on load, the mobo reads the 3.3 at 3.29 and 5v at 4.99/5.02, 12v 12.16.
pic of ERROR
pic of ERROR
