Rebooting
AMDXP
Ok well I have a custom comp and I want to reboot, I dont really want to install the drivers again, I just want everything such as my games and etc to be removed when i reboot.... Do I have to reinstall the chipsets and etc again or sohuld they be already on there?
Is this a reboot as in Turning the computer off and then on again? If it is, then no, nothing will be gone.
If its a Format and Reinstall windows (Which i think you meant...) Then everything will be gone, so you will have to reinstall drivers for everything, all your games, everything. (Unless you partitioned drives so you have a boot partition, and a storage partition or something...)
Edit: You could just Uninstall all your games, and delete/uninstall everything else you dont want, if that helps, but i don't think its what you're going for...
If you are going to format [assuming that's what you want to do], then you will want it to be fresh. It's a pita sometimes, but at least your computer will be fresh with no problems.
It doesn't take THAT long to install drivers :)
