Reboot = Everything in Gibberish
vaughty
I just installed a login screen using StyleXP and then restarted my computer. When it got to the login screen all the text was in symbols similar to the Webdings font and now I can't do anything to get rid of it (it's making my computer completely unusable).
I have tried changing to the normal login screen (only managed that through using the icons to navigate), then rebooting but the same thing happens. I tried uninstalling StyleXp (again using the icons to navigate) but nothing again.
I really need to get this sorted cause Im in the middle of my research project for my Masters and I can't afford to lose any of the work through a format.
Any help/ideas would be greatly appreciated.
Thanks inadvance,
vaughty
Have you tried booting from the XP CD and doing a repair install? That would be probably be your highest yield strategy at this point.
Sounds like you learned a lesson the hard way. ;)
what about right clicking the desktop and going to diplay properties and trying a different window's scheme?
