peters.peter
- Feb 23, 2005
Hi I hve been running my Mobile 2500+ at 2.4Ghz without a problem. I was using an old Thermaltake Volcanoe 9 as the heatsink, and just today purchased a CoolerMaster Aquagate H2O system. I can bring the temps lower than they were before while using the maximum fan speed, but that is way to noisy. If I lower the fan speeds to the lowest settings the temp according to MBM is 57C after a good hour of running prime torture test.
My main question is what is to high for my CPU, and what is a prime temp? How high do experienced o/c'ers let it get. I really purchased this system to bring the noise levels of my machine down. Unless I use settings 1 or 2 it's not quieter, and even setting 2 is barely quieter.
So if anyone with experience overclocking these mobiles could give me info it'd be great.
Thanks in advanced.
Thanks in advanced.
