reasonable expectations for an x800xt agp?
Stupid2
well, I just got my x800xt in the mail today and have thrown it into my pc and begun playing around with it. Now I know this isn't the baddest card out there but I'm going from an old geforce3 so...yeah...seems like it to me :D . Anyway, I'm trying to determine what kind of reasonable expectations I should have of this card, say for example, farcry, what should I reasonably be able to set things to at a playable level (messing around right now with everything on high, 16af and 4aa at 1600x1200 and that is ~playable but stutters a little bit here and there)?
I did run 3dmark05 and got a score of 4325 (not sure what that means really) and the rest of my pc isn't exactly high end - an 2700xp processer and 1 gig of kingston ram (I think, don't remember brand or timing to be honest).
Anyone have some insight for me here?
thanks much!
get new system cuz ur current puter is hurtin x800xt performance. all u have to do is add more AA and AF durin the gameplay and u will notice somethin different with same fps. :)
yeah I assumed as much, unfortunately, no budget to upgrade anything else for awhile yet. Any other comments on reasonable expectations (just tried running the fear demo with everything on max at 1152x864 and hit quite a few slow downs - reasonable?)
thanks again!
Apple740 said:
This is not optimal (unless you benched with AA/AF). Normally it's around 6000 for a X800XT.
really? I checked other projects on their site and the only ones I saw that hit the 6000's were overclocked x800xt's (at least what I saw) - I did notice that one with similar system setup to myself and a stock x800xt hit 4900 which is still a fair bit above what I managed to peg.
Are you running the latest Catalyst's and your chipset drivers are all installed? That's what I would check first thing.
I have a similar system with an X800XTPE on the way, so when it gets here I can let you know my test results.
UltraCow - I am using the latest cats however I'm not certain about my chipset drivers, I will need to check that (will hold off though as I'm reformatting and reinstalling onto a new hd this weekend). Do let me know what your results are though when you get things in and set up if you could.
Bah, that was strange - had ati tool running to auto detect overclocks for gpu and mem and in the middle of that the screen pixallated and I got a note that the drivers had auto recovered the vpu (of course now the ccc is reporting a temp of 20c obviously wrong).
strange thing is that ati tool was running that whole time, right through the vpu recover...
anyone have any idea why my gpu clock would be throtled down from 500mhz to 399mhz while playing? (it seems like atitool is causing that but I'm not really sure where that is set...??).
thanks!
mmm heat issue is somewhere there. prolly ur stock heatsink on x800xt isn't givin off the heat really well. Try to remove ati tool and all the ocing stuff then play some games. Also don't forget to dl everest ---> www.lavalys.com to check the x800xt speed and the temp of it. ;)
hmn..yeah I'm guessing its the ati tool causing the troubles - running 3dmark05 after installing ati tool netted me about 1000 points less then when it wasn't installed. I guess I just have to find the setting that tells ati tool to undercolck the gpu (didn't even know it had that functionality and I would've thought it would be located on the overclocking screen. Go figure).
btw - anyone think it is unsafe to just try running this thing at pe speeds, e.g., 520 gpu/560 mem and running it through a few loops of 3dmark05 and games to test for stability/artifacts (ati tool is just pissing me off) instead of slowly incrementing speeds for both core and mem (based on the reviews I've read, this should be able to hit pe speeds w/o a sweat)?
I don't think it would be a problem, although you may want to try using ATI Tray Tools as ATI Tool seems to be giving you trouble.
If you have any underclocking trouble with ATI Tray Tools, just check the "Auto 2D/3D Overclocking" section for anything set wrong, although it's by default not used...
Your rig seems fine for that 3Dmark score, to be honest you won't hit 6K without an A64. Like a few others said, just crank the eye candy up to give the card a work out.
The lowest X800 XT score that I have on my list is 5,128, but I don't know what CPU that guy had.
He was running his XT at stock speeds as well.
Do you have a brand name 350Wattish power supply?
mentok, I have a 380watt antec true power psu (stock that comes with the sonata case). I'll be wiping and reinstalling on a new drive this weekend so hopefully I'll iron out some of the bugs with performance then - curious if those scores you were seeing were agp or pcie?
There shouldn't be any difference between the two cards exept for margin of error.
yeah I'm not sure what is up really - the problems I was having were with ati tray tool (e.g., the gpu throttling) however, I just ran two successive tests of 3dmark05 with the card set at 525 core and 561 mem and got a 1300 point difference between the two. The first test was run with ati tray tool overclock which reported a min dip in the core to 499 and a min dip in the memory to 510 and a final score of 5587 and the second was with ati tool which recorded a final score of 4225. The catalyst drivers don't appear to note the changes in mem or core at all in the catalyst control panel though - do the settings I have in the 3d section of the catalyst drivers have any affect on the free version of 3dmark05 (I have everything set to the highest)?
thanks much for all the input guys.
--edit--
hmmnn...just noticed something. If I set mem and core in ati tool and then run 3dmark05 even for a second (literally just as it finishes loading the first demo) and then exit 3dmark05 and click back on ati tool, my settings will drop down to 507 core and 501 memory from 525 core and 561 memory - has anyone experienced behavior similar to this....? thanks!
yup was doing that
seems to have gotten a bit better after reinstalling on a new drive, score on stock now is 5572 in 3dmark05.
thanks for the help and suggestions everyone! (any further tips and tweaks are quite welcome).
Athlon 64(I would suggest a San Diego core, if that too pricey go for the Venice core) + DFI Lanparty + 500W PSU(a must) + OCZ ram = no more bottlenecks.
Received the ATI X800XT PE AGP ordered at ATI Online Store. The order said refurb but this looks to be a brand new OEM card that was never installed. I took back the recently bought X800XL at CC.
Comparison on a P4 3.0 Ghz @ 3.52 Ghz /Abit AI7/ 1 GB 468 DDR Dual Channel
9700 Pro Stock Speeds 324/310
X800XL - Highest O/C - 435/545
X800XT-PE Stock Speeds - 526/560 (w/OverDrive enabled)
3DMark 05
9700 Pro - 2,176 3dmarks
X800 XL - 5,287 3dmarks
X800XT-PE - 6,057 3dmarks
3DMark 03
9700 Pro - 5,229 3dmarks
X800 XL - 11,595 3dmarks
X800XT-PE - 12.692 3dmarks
The X800XL was $270 w/tax at CC (minus a 30$ rebate not sent) and the X800XT-PE was $238 shipped. If you had a 9800 Pro or lower and didn't get in on this deal you should be kicking yourself!
I'm also looking to do a mini-upgrade to an Athlon64 +3700 San Diego & MSI K8N Neo 2 (NF3) AGP mobo (about $400 total) in the near future, but I do wish there were some NF4 AGP mobos available....
Ok, sorry that this is a bit late, but I finally got my XTPE in a few days ago, and have been getting everthing set up.
Anyway, 55XX sounds about right for an XT running stock. I get about 59XX at stock with this card with a slightly faster AXP, so your score seems to be perfectly in line.
