football76
- Jan 23, 2008
Ok, I built a small, basic PC for my parents. I used THIS motherboard. So, I finished installing everything and go to boot for the first time... Nothing. Absolutely nothing. Checked all the connections and so forth, still nothing. Then I unplugged everything from the back panel and tried powering on, success! Plugged the USB KB/M and VGA monitor in... Monitor works as normal, but the USB ports aren't even getting power (tested them, not a single volt), nor are the PS/2 ports. However, the front case panel USB ports work without any problems. I thought this was a chipset driver problem, but after installing the latest, still nothing. And yes, I've enabled everything in the BIOS. So, I dismantled the PC and ran it outside the case to see if there could be a short somewhere, nope still nothin. I decided to RMA the board and head over to MC to pick up a replacement. Picked up THIS and reinstalled all the other hardware. Same exact problem!!! What gives? This has to be a software issue right? What else can I do? I'm not an expert with windows BTW, but I am competent. The PC is running Vista Ultimate 32-bit SP1.
Sorry for the long post, but I am absolutely stumped on this one. I really appreciate your help guys!
