Lemonjello
- Mar 12, 2011
I had already applied the paste and partially attached the hsf but then I had to remove it again; I'm thinking I should reapply it due to air bubbles or whatever, but it was a real bitch getting the pre revision AC Freezer Pro 7 on my Asrock P67.
Will it make a significant difference if I leave it as-is?
Im running 33-34C stock CPU speed at idle but I want to OC soon.
Thanks
Thanks
