Reapplied grease, not Vcore not dropping with EIST / C1E / Speedstep!
Spare-Flair
My normal overclock is 9x400 = 3.6GHz @ 1.4V but I desperately need the voltage to drop when I am not doing anything intensive to reduce heat and noise. This was working perfectly last night, I would use CPU-Z and watch my Vcore automatically drop when it drops my multiplier to 6x400 = 2.4GHz, it would drop the Vcore down to 1.2V (or something like that, I can't recall exactly what it was).
However, today, I reapplied my arctic silver and reassembled the computer and posted up and now while the system will drop the core to 2.4GHz by automatically reducing the muliplier, it refuses to change the core voltage and so my fans are going nuts in windows.
I definitely have EIST and C1E on in the BIOS, I haven't changed that at all. I've done nothing aside from unmount and remount my HSF. The core voltage is stuck at 1.4v nomatter what I do and nomatter what the multiplier is auotmatically dropping. Is there something wrong with my speedstep? Is there a way to manually do this? (RMClock worked last night, isn't working anymore apparentely).
I have load line calibration on (but this was on as well last night and speedstep still worked) and I have tried the various windows power states (always on, max battery, etc.) to see if that affects anything but no dice! What is wrong???
If it were me I would just try resetting CMOS, hop into windows with defaults and see if it works then. Then go one step at a time with your OC, making sure speedstep is working along the way. Probably the easiest method.
I've cleared my CMOS twice, I've booted into a secondary partition that has a brand new install of windows.
I've posted at all defaults right now, no overclocking at all, just optimal defaults in bios and everything is at stock. Even at stock the vcore isn't dropping either even if the multiplier is.
IE, what CPU-Z is currently showing is:
9x266MHz = 2.4GHz @ 1.232V
then it drops the multi to 6x266MHz = 1600Mhz Vcore is still 1.232V!!!
I'm paranoid that I possibly damaged something physically on the motherboard or CPU? Because I've eliminated all other software/bios problems I can think of.
Hm. I doubt you've damaged something since everything is working. Try to re-download CPU-z. If that doesn't fix the problem I'd suggest going into the power management settings in windows (are you using 7?)
Iirc when set to certain power settings windows won't lower the multi, maybe in your case it's just doing that with the power.
I'm on XP but yes I've tried all the power management options (always on / portable laptop / max battery, etc.)
Tried other apps like Lavalys Everest to monitor voltage and it definetely isn't changing and I definetely know it is not dropping because I know what temperature the CPU should be when speedstep used to drop the voltage. Now it's stuck on the overclock voltage and I really only want that when gaming.
I'm not sure at this point what it could be. When I get home I'll fiddle with some BIOS settings and see if I can replicate the problem. See if there's a new BIOS version maybe that mentions any issues.
I've just tried RMClock and CrystalCPUID to change the speedstep voltage manually, it does nothing. CPU-Z reports 1.376V constantly.
I've also just flashed my bios to the latest version. I think something must be seriously damaged. My entire system also seems to be much hotter than before, about 10 degrees hotter on CPU, RAM, chipset, system temperature, on everything Even the PSU is much louder than it was last night as it tries to pump out air.
CPU temperatures are 60° C when idling when it was around 50° C last night (I wrote them down as I was doing benchmarking).
Man, what the heck went wrong? This computer is kind of useless to me without speedstep because the difference in having the CPU voltage that can drop by itself in windows 80% of the time that I am using it (ie: not gaming) is 10-15° C for the entire system and all the fan noise, etc.
maybe it just needs to melt the grease, run IBT on it for a while and see how hot it gets. when it gets back to idle it should eventually cool down. if not then maybe you did not seat it properly.
Yes I'm reseating the heatsink tonight but that leaves the issue of C1E not working. I think something must be wrong with the motherboard but this was working for the past 3 weeks I've had this board.
Now it simply doesn't.
I've reseated the heatsink and reapplied AS with the line method. Temps are 10° C cooler now but I am forced to run the system @ 3.4GHz with 1.375V because it's too hot without C1E / EIST / Speedstep working, ie: temps will build up slowly over a few hours of surfing the web, etc. when ideally, the voltage would automatically drop about 1.5V itself and keep everything cool when I wasn't doing intensive tasks.
I'm still really miffed and chuffed about this, are those functions motherboard or CPU dependent? The board is barely a month old and this has stopped working out of the blue. This is a very important and vital feature for me and is a deal breaker on a computer I just built over several weeks. :(
Many motherboards and bios versions don't drop the core voltage when using SpeedStep / C1E as soon as you start overclocking. They think they are doing you a favor and making sure that your overclock will be stable.
Make sure your Minimum processor state in the Control Panel -> Power Options is set to a low number like 5%. In XP you need to use Laptop/Mobile or something like that in the Power Schemes.
RealTemp should report the EIST bit correctly and will let you toggle C1E from within Windows.
http://www.fileden.com/files/2008/3/3/1794507/RealTempBeta.zip
It doesn't make any sense to me that it was working and now it's not but it's definitely motherboard dependent. Did you update your bios recently?
Thanks, I was already using realtemp and the C1E box is available but EIST is greyed out.
Additionally I was previously using Rightmark Clock Utility and with that I could force the lower 6x state with the corresponding drop in voltage but that doesn't work anymore either. The same happens with CrystalCPUID where it used to work and nolonger does.
I definitely was doing 3.6GHz @ 1.5V with C1E/EIST working as it would often drop down to 2.4GHz at around 1.2ish volts and this was observable in coolmon. Made a huge differences in CPU and system temps (and my fan noise) when I wasn't gaming which is important to me.
I did play with the power options to laptop / mobile / max battery, etc. and even tried the command line powercfg.exe editor to get at them directly but it made no difference. Besides, when it did work only the other day, I think I was on home office/desk anyway or minimal power managment and it would still drop the voltage automatically.
The only thing I noticed is whether or not I have Load Line Calibration on or not, the voltage in CPU-Z (and other CPUID programs) will be constant and not fluctuating like I was used to seeing. Either it's not working or the vcore / VID is being reported incorrectly.
I've taken all the software issues out of the equation (booted on XP and Windows 7 on different installs) and I've reset my bios countless times playing with the C1E and EIST functions are on and off but I still can't get it to work. I flashed my bios after this problem came up in a desperate attempt to fix it but the problem persisted. I've flashed it twice now with different versions and nothing has changed. Voltage still isn't dropping in windows.
Must be a hardware issue or some kind of unintentional motherboard damage when I mounted the heating again? I also had one stick of ram not all the way in when I powered the system on accidentally but I noticed this right away and reseated it. That's honestly the only thing that changed. One minute it worked and 15 minutes later after reapplying AS and reseating the heatsink and reassembling the computer the function is broken and I haven't been able to get it to work since.
I've got a UD3P Rev 1.0 and a Core2Duo E8400 @ 4GHZ and with C1E and all the others enabled I've never had it drop my vcore at all, MHZ yes but never Vcore. Unfortunately I don't know enough about it all to say whether that means anything or not.
Have you tried posting on Tweaktowns Gigabyte section? Might find someone like LSD who knows what the Mobo/CPU should be doing with these settings on or off.
AFAIK the voltage drops only happen when voltage is set to auto. But I could be wrong. Ask in the overclocking & cooling section, this is more of their gig.
You seem to be pumping a lot of volts into that proc to begin with. Just my observation. Especially if you say it's too hot for daily use, then why run it that hot?
