RealTemp - RivaTuner Plug-In
unclewebb
I just added a RivaTuner Plug-In to RealTemp:
http://www.fileden.com/files/2008/3/3/1794507/RealTempBeta.zip
Open up the RealTemp - Settings window and click on the RivaTuner button to install this plug-in into RivaTuner. You can now use your RealTemp calibration settings in RivaTuner. Your calibration settings will automatically be saved to the RIvaTuner plug-in when you push OK in the RealTemp settings window.
Once installed, the plug-in is stand alone so you don't need to have RealTemp running. You will be able to see CPU MHz, CPU Load, core temperature and Distance to TJMax on your G15 keyboard now when RivaTuner is running. Just select the RTCore.dll plug-in in RivaTuner and you're good to go.
Awesome! gonna try this when I get home. I wish they would make an everest plugin... =[ I like to see my Nb/SB temps too!
Almost forgot, it works good in Windows 7 as well:
