Really wreird power problems..
Major problem....
Ok to start things off here are my specs.
1.Mobo- GA-ma69GM-s2h
2.GPU- EVGA e-Gefore 8800 GT
3.CPU- AMD 6000+
4.PSU- Corsair VX550 W
5.PSU(2)- Thermaltake HPC-420-102 DF
6.(x2)Mem- OCZ PC2 6400 1 GB dual Ch Platinum Revision 4-4-4
Ok, little background
I have been running my computer without the GPU and with PSU #5 (in the list). From about Christmas time... I then got enough money for the new G-card, and new PSU to run the G card. So I bought the G-card and ran that on the 420 W PSU I already had for about 2 weeks. Then I order the thew 550 W PSU. (and then this is where everything goes to hell).
The problems (hell)
I received the new PSU in the mail and popped it in. I plugged the 2x12 pin into the slot and left the 2x2 ATX power pin plugged in. (assuming the extra 4 on the 2x12 was the 2x2). I then continued to power it on and saw that it wouldn't post (but the CPU fan would still spin). I then thought well, I guess I will unsnap the two on the 2x12 and plug it into the 2x2 slot on the mobo. (so kinda like my old set up). I then continued to power it up and noticed nothing really happened, and then though to myself, must not want to work that way. So I plugged it back in how I had it the first time, and noticed that the CPU fan was no longer spinner, and that I couldn't not get a post out of it. I then tried my old power pack and still same thing, CPU fan would not spin or post or do anything.... I then figured that maybe the mobo went RIGHT as I got a new PSU though the chances where slim.. I then called gigabyte and got a replace mobo in the mail (3 LONG LONG LONG weeks later).
I just got the mobo today and popped everything in. Plugged in the PSU 2x12 pin into the 2x12 pin socket and then noticed that CPU fan would now spin, (woot) they fixed it.!! BUT, it still wouldn't post..... I then tried to do what I did last time and unclipped the 2x2 off of the 2x12 and plugged it into the 2x2 spot and the 2x2 into the 2x12 slot. And then same thing. CPU fan stopped spinning. And now im back to where I was.......
I then noticed that the 2x2 pin that I unclipped from from the 2x12 stack, didn't quite fit into the 2x2 slot on the mobo. That it actually fit into two different directions... (there is no clip to now for sure). I then looked at the orientation for the squares on the clip and noticed that it did not match up in ANY direction.....
So right now... I am at a COMPLET loss....
There is no way I can wait ANOTER 3 weeks for a new mobo from gigabyte....
Please help...
I am fairly confused as what you say makes no sense or I am not sharp enough to figure it out. /shrug.
If you do not use the "snap off" extra connector on the ATX main power connector, the extra ATX "snap off" goes NOWHERE. The power supply has a dedicated connector for that.
Again I had difficulity following you but as far as I can tell this is where you went horribly wrong :
The above is incorrect.
The VX has either a dedicated 12V Aux 2x2 or an 8 pin you snap in half, I honestly cant remember atm despite having one of those fine supplies myself. But there is a dedicated connector for the 12Vaux, you do not use the "spare" or "unneeded" atx main power connector pins.
Gigabyte has a how to install a motherboard video on their main site, might be worth a look if the power connections are still unclear.
Sorry for your troubles.
Looking at their specs on the site, and kinda guessing what you did, the 'main power wire' is adaptable for either 20 or 24 pin motherboards with a 4 pin adapter that snaps onto the side. There is also an 8 pin wire that you can split that plugs into the other socket on the motherboard. If you unsnapped the 4 pin from the 20 pin and plugged them into different sockets on the motherboard, you most likely smoked it.
OO, you guys are awesome... Yea, i didn't notice the 8 pin that snapped in half, which then became the 2x2 pin ATX......
Because on my old power supple it didn't fill up the full 2x12 only was a 2x10 and then has a separate 2x2 that plugged in. So i assumed that on the new 2x12 that the the 4 just just clicked off and and plugged into the 2x2 by the CPU...
But Thank you soo much for clearing that up!!!
EDIT: But the weird thing is... was that 2x2 i popped off the 2x12 FIT into the 2x2 slot on the other side in two different ways... I figured if it fits it must be right, but then looked closer and noticed that that it didn't line up exactly But still fit...
Yes it is a horrible design and gee, would it fracking kill everyone to come up with a simple color code so the sockets on the board and the connectors on the power supply had matching colors ? Even just color coded stripes or dots ? Yes, apparently yes it would, the universe would spin out of control because manuf would be unable to give us those gut wrenching, eye poping, God awful color schemes they think we like or someone would not buy a board becase the red stripe did not match their all blue color scheme.
Dont get me started in the front panel connections to the motherboard !!! :mad:
