Really wierd problem, need some help
shoman24v
I have an AMD X2 3800+ OCd to 2.5GHz, an ASUS A8N SLi Premium motherboard, an Antec NeoPower Modular PSU with a Lian Li PC-65B. Recently I've been having problems with the computer not wanting to turn on after the power has been disconneced from the PSU. If I plug the wire in the PSU the motherboard light comes on but if I try to hit the switch nothing happends. After tinkering with it I can finally get it to turn on. What's weird is that once I can get it to turn on after it's been unplugged the computer will turn on and off fine when pressing the button. I've tried to jump the "Power SW" with a copper wire by just touching the two pins coming out of the motherboard but that didn't do anything (I don't know if I'm doing it right?)
Why is it that when I unplug my power cord and plug it back in I can't get the thing to boot? But once I get it to boot the thing works fine?
"Why is it that when I unplug my power cord I can't get the thing to boot? But once I get it to boot the thing works fine?"
maby cuz the psu has no power? ok im jk
i would try unplugging everything but the bare minimums and seeing if that effects the situation.
lol fixed. I will try that now.
Nope, didn't help. I still have the light on the MB but it won't turn on.
It may take 30 sec or so for the psu to power up. I know with my Antec smartpower, if I unplug the power then plug it back in, it takes a few seconds before I can get it to boot. That's why I just always leave it plugged in. I used to always switch off my psu when I shut my computer down, but that was with my old psu. With my new Antec one, I don't do that anymore because I don't want to wait for the 30 seconds. You may be experiencing the same thing.
Yeah, I waited on it, even overnight won't turn on... Is there anyway I can test it to see if the switch is getting the proper voltage?
I'm thinking the PSU is bad, but once the computer turns on it works fine lol... I may have to take it to my work and start swapping parts out to see what's the deal.
Ok, so I tested a new power supply in my machine. The computer started up fine so that rules out bad motherboard. So I take the power supply from my computer and put it in a new computer from work. It works on that computer too lol. So I plug my power supply back into my PC and I get nothing out of it.
My power supply works fine on the new PC for work but won't work on my PC... strange huh...
Hmm. Strange indeed. At any rate, I'm glad to hear you figured out the problem.
Sorta... I know that if I got a new PSU my PC would work, but at the same time, my PSU is good...
Nevermind, bad PSU. Only works when going 24 to 20 pin but won't work in 24 pin mode :rolleyes:
Computer I did orignal test on was 20 pin, mine is 24 pin. Tested on another 24 pin motherboard and it didn't work.
