Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Ok, for overclocking your RAM, if i have ddr400 ram, I can't go above 200mhz for the speed, correct? So I would have to OC on a ratio? Just checking if I have my info right, if not, I'm getting too old...
it will run 200 mhz.. at its stock voltage and timings..
and probably a little bit more.. but you can always increase voltage and loosen timings to get higher clock speeds... however these won't be supported, warrantied, or guaranteed... but you probably can do it.. at least with quality ram...
Ok, this is what I thought, but I'm not able to go over 200mhz in my bios. Does anybody know how to do this with my mobo (in the sig) i'm running the 3/8 bios.
