Sabertooth 990FX R2, upgrading a happily working 7970 crossfire setup to a 280x crossfire setup, which is pretty much the same junk.
So, we run the AMD install manger, yank the vid driver and CCC, shutdown, R&R cards, boot it back up, install the Cat drivers, reboot, video is good, audio is gone.
Audio never came back.
I have tried every combination of installing, uninstalling, and even going back to my original card and card(s), restore, etc, nada. See video for repeatable weirdness.
https://www.youtube.com/watch?v=ZTQokMwwCjs
It does that, forever. Nothing is being plugged into any jacks, the rear jacks were not touched till a problem popped up, the fronts were never used, the motherboard plug was not disturbed and I checked it. The 280x's are fine, bench well, no artifacts, nothing. I disabled onboard audio in the bios and other than no sound, the comp is fine.
Either something really freakin weird is going on, or the onboard audio just decided to die right when I was swapping cards, possibly from a short in the actual jacks on the back of the board. I was as careful as I've been with the hundreds of other cards I've swapped in the last twenty years. As an interesting aside, the last Asus board I had, an AM3 with the previous gen chipset, the onboard LAN died two weeks into owning it, least this one made it like, six months..
Any other ideas? Tomorrow I order a USB soundcard, since there isnt' room with the crossfire going on.
