AND ITS ALL OBLIVION's FAULT!
Okay, not really but still. The problem started when i went to update my x850xt to the catalyst 6.4's. I used driver cleanup to remove everything, but then when i went to install the new drivers, i get stupid errors. Its basically rcp saying failure and whatnot. If i try to install them in safe mode it says that I dont have vga controller drivers. Hmmm. That made me a little suspicious so I went into device manager and there is nothing. Yes, plug and play is enabled and yes my erum permissions are correct in the registry.
Nope thats not it! I was fooling around trying to fix the problem and now it seems to be worse. I get no video at all after the XP loading screen. I know my video card is FINE. Its just stupid driver problem.
Now I just really want to reformat and get everything back to normal so I can play oblivion ;]. However, when I boot the windows CD i lock up on "Setup is inspecting your hardware configuration".
Soooo i really need some help cause im pretty ****ED.
AMD 64 4000+
DFI Ultra D
x850xt
gig of OZ pc4000 vx
AMD 64 4000+
DFI Ultra D
x850xt
gig of OZ pc4000 vx
