nlancaster
- Feb 24, 2005
A few years ago I saw this crazy mod over at bit-tech.net, Orac3 by Peter Dickison (G gnome). And he had these beautiful hose clamps. At the time I was not water cooling but thought those clamps looked really good. So a few years go by and I am doing water cooling, first project, and latest project. And I got to thinking about those hose clamps again. I like the Koolance compression fittings I have been using but they are used by many people. I don't really care for the bitspower and feser compression fittings, I don't like the patterns they use. So I went looking for the fitting Peter used. Yes, They are a little spendy but they sure look good. Also you could have them reanodized to your color, or possibly even powder coated with the rest of case to match. And I finally tracked down a company that has them, and thought I would share them with everyone here.
The come in 2 different designs.
Spanner Locks, required to purchase special tools to install.
Hex Locks, normal hexagonal bolt style. It is recommend to buy AN fitting tools, they are aluminum tools, to not damage the finish on the aluminum clamps.
Manufacturer - Pi-Thon Design Inc.
Reseller that has them - Wildpony motorsports.com, Linked to all the Pi-Thon products on their page.
Fittings for 3/8 inch OD
Fittings for 1/2 inch OD
Fittings for 3/4 inch OD
